Bộ phần mềm RCC, RCBc báo lổi
10-01-2017, 01:38 AM
Chào anh Hùng, vui lòng check giúp em lỗi sau:
[Hình: gui_a_10.png]
Cả 02 phần mềm RCBc và RCC đều chung lỗi này.
Cảm ơn anh,
.rar  ks tran binh trong.rar (Kích cỡ: 237.36 KB / Tải về: 59)
 Thanks given by: hattievy1 , RobertWem , Agnesrhinee , AdavidEpift , EduardMob , Karenrhinee , JefferyLah , Husecyscounse , FozzLed , eileencq4 , jamiefp60 , bertieym16 , judithzm3 , rhodawc11 , angieiq16 , lawandaoq60 , jeffpm60 , deloriseq11 , cassiepr69 , vondanx60 , arlenebj11
10-01-2017, 01:44 AM
RE: Bộ phần mềm RCC, RCBc báo lổi
Toàn bộ code bao lỗi như sau:
Code:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.Data.SyntaxErrorException: Syntax error: Missing operand after '' and LineType ='' operator.   at System.Data.ExpressionParser.Parse()   at System.Data.DataExpression..ctor(DataTable table, String expression, Type type)   at System.Data.Select..ctor(DataTable table, String filterExpression, String sort, DataViewRowState recordStates)   at System.Data.DataTable.Select(String filterExpression)   at  .(Boolean )   at  .(Boolean )   at Reinforced_Concrete_Beam_Calculation.frmMain.(Object , EventArgs )   at Reinforced_Concrete_Beam_Calculation.frmMain.(Object , EventArgs )   at System.EventHandler.Invoke(Object sender, EventArgs e)   at System.Windows.Forms.Form.OnLoad(EventArgs e)   at System.Windows.Forms.Form.OnCreateControl()   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)   at System.Windows.Forms.Control.CreateControl()   at System.Windows.Forms.Control.WmShowWindow(Message& m)   at System.Windows.Forms.Control.WndProc(Message& m)   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)   at System.Windows.Forms.ContainerControl.WndProc(Message& m)   at System.Windows.Forms.Form.WmShowWindow(Message& m)   at System.Windows.Forms.Form.WndProc(Message& m)   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------RCBc    Assembly Version: 1.1.0.0    Win32 Version: 1.1.0.0    CodeBase: file:///C:/KetcauSoft/RCBc/RCBc.exe----------------------------------------Microsoft.VisualBasic    Assembly Version: 8.0.0.0    Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------System    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Windows.Forms    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Runtime.Remoting    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5488 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll----------------------------------------System.Data    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Xml    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5494 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Accessibility    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.Management    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll----------------------------------------System.Configuration    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------System.Transactions    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll----------------------------------------System.EnterpriseServices    Assembly Version: 2.0.0.0    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)    CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration>    <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Trích dẫn:
 Thanks given by: latoyant4 , benkq3 , Marrybax , LoanLaugs , ZorroDaf , Londruvwed , monavo16 , louiseuu4 , kimberleycb3 , neldarq1 , darrenlv3 , lawandaoq60 , albertojm18 , sharlenewp18 , frankvo16 , DonaldDit , Cecilnig , lizziepd11 , merleiv18 , rosalindaad11 , katydg69 , janicetl60
10-01-2017, 08:12 AM (Bài viết đã được chỉnh sửa: 10-01-2017 08:13 AM bởi Ho Viet Hung.)
Em gửi đầy đủ các file dữ liệu theo thông báo tại đây để bên anh kiểm tra em nhé, cần thiết nhất là file MDB và mô tả rõ thời điểm gặp thông báo lỗi: http://www.ketcausoft.com/forum/showthread.php?tid=1998 ,
 Thanks given by: carayp11 , Dallasbeill , RockoTact , Merdariongap , HjalteRes , ZorroDaf , bobbieuq69 , karinaqq16 , fredso18 , carolyc3 , ineslu69 , angieiq16 , mageadlola , albertoqz2 , friedasj4 , lawandaoq60 , sharrondu18 , magdalenawq18 , jeannetteym18 , tylerai1 , lizziepd11 , jaimext16 , Amefssips , tomog16
10-01-2017, 01:40 PM (Bài viết đã được chỉnh sửa: 10-01-2017 01:44 PM bởi mr.thieu.)
File MDB khá nặng ạ, anh vui còn check email info.ketcausoft. Em có gửi kèm anh file Etabs V9.7.4 Khi mở phần mềm KCsoft thì bình thường, nhưng click mở file MDB kết quả từ Etabs thì gặp báo lỗi như trên, phần mềm bị treo và thoát ra ngoài.
 Thanks given by: HaroldBow , arlinebu60 , Agnesrhinee , Stavetlerorge , StepanNam , Phincbhp , elisalp69 , abigailgn18 , anastasiarq18 , marvinyu11 , leroyex11 , margeryzj1 , murielwg60 , andyab3 , vickiexl60 , marissabu2 , sharlenewp18 , nancyad60 , Cecilnig , stacipo18 , ivabi3 , maryellenbz11
10-01-2017, 01:54 PM
Anh không kiểm tra file Etabs mà chỉ xem file MDB thôi em ạ, vì như thế mới biết được lỗi, em up lên Media file rồi dán link vào đây nhé, lưu ý em lần nữa phải nêu thật rõ ràng quá trình gặp lỗi, xem kỹ thông báo tại đây: http://www.ketcausoft.com/forum/showthread.php?tid=1998
 Thanks given by: freidaqf16 , sharrongs2 , CharlieEn , Hubseshobre , Alexskill2798 , Robertver , lilytm2 , brandiewx2 , Stephenlib , KaxaLed , JosephZep , luzgy2 , latishawg2 , celiaqb60 , brendabi3 , manuelakh60 , edithzu16 , everettwv1 , gilbertsw60 , virgiesn4 , robinhx16 , DonaldDit , arleneeb3 , michaelfp16 , marionlh18 , Mariojob , edwinatp16
10-01-2017, 03:48 PM (Bài viết đã được chỉnh sửa: 10-01-2017 03:49 PM bởi mr.thieu.)
Chào anh, vui lòng check giúp em: Quá trình gặp lỗi như sau: Sau khi Export nội lực từ Etabs, mở phần mềm KCsoft lên, mở file MDB lên thị gặp báo lỗi như hình trên/
http://www.mediafire.com/file/qimc52bs1b...ausoft.mdb
 Thanks given by: friedasj4 , marissabu2 , Karenrhinee , RockoTact , diannaor4 , Stavetlerorge , Phincpae , nevakv1 , luzgy2 , corrinefo16 , brendabi3 , magdalenawq18 , rachaelct3 , claireeu18 , angelate60 , biancaxn4 , lyndaup1 , corrinetf18 , williefj2 , oscartu3 , marcydr16 , thelmano11 , michealjw4 , chriscl69 , fernqy60 , jerryvn11 , Mariojob , byronql69 , pollynj69
11-01-2017, 02:08 PM
(10-01-2017 03:48 PM)mr.thieu Đã viết:  Chào anh, vui lòng check giúp em: Quá trình gặp lỗi như sau: Sau khi Export nội lực từ Etabs, mở phần mềm KCsoft lên, mở file MDB lên thị gặp báo lỗi như hình trên/
Chào em
Lỗi phát sinh là do cách đặt tên tầng của em, em đổi tên tầng thay vì bằng số cao độ như hiện tại thành có thêm chứ cái phía trước là ok em nhé;
Ví dụ thay vì +7.000 em đổi thành EL 7.000 là OK em nhé
 Thanks given by: nancyad60 , Karenrhinee , TomZAoff , noelleno69 , lilianawf60 , edithzu16 , claudiara16 , lizziepd11 , morrisua11 , rosalindaad11 , Amefssips , lynnetteir16 , faithnc4
12-01-2017, 12:13 AM
Da, cam on anh,.
 Thanks given by: Agnesrhinee , KaxaLed , Eugenekef , jaygv60 , sheilazp16 , lakishajo1 , alanaop2 , joyceyq18 , Jamalpuple , gwendolyngq1 , patriciafb2 , rachaelct3 , claireeu18 , leonardcc3 , nancyad60 , duanexr18 , nicholepn11 , danielletm18 , morrisua11 , kathrinefn60 , katydg69
