LỖI KHÔNG SỬ DỤNG ĐƯỢC LỆNH KCS
04-07-2019, 11:28 AM
LỖI KHÔNG SỬ DỤNG ĐƯỢC LỆNH NÀO CỦA PHẦN MỀM KETCAUSOFT
EM ĐÃ FIX THEO LỖI SỬA ACAD TRONG Ổ C: NHƯNG KHÔNG ĐƯỢC.
MONG ANH HÙNG VÀ MỌI NGƯỜI CHỈ BẢO. XIN CẢM ƠN!
Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef,
Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
at loadmgd()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure
logging.
To turn this feature off, remove the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog].
netload Assembly file name: C:/KetcauSoft/KCS_Plotter/KCS_Plotter_GstarCAD.dll
Cannot load assembly. Error details: System.IO.FileNotFoundException: Could not
load file or assembly
'file:///C:\KetcauSoft\KCS_Plotter\KCS_Plotter_GstarCAD.dll' or one of its
dependencies. The system cannot find the file specified.
File name: 'file:///C:\KetcauSoft\KCS_Plotter\KCS_Plotter_GstarCAD.dll'
at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase,
Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark,
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS_SFD/KCS Spread Foundation
Detailing GstarCAD.dll Cannot load assembly. Error details:
System.IO.FileNotFoundException: Could not load file or assembly
'file:///C:\KetcauSoft\KCS_SFD\KCS Spread Foundation Detailing GstarCAD.dll' or
one of its dependencies. The system cannot find the file specified.
File name: 'file:///C:\KetcauSoft\KCS_SFD\KCS Spread Foundation Detailing
GstarCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS_STK/KCS STK Net GstarCAD.dll
load file or assembly 'file:///C:\KetcauSoft\KCS_STK\KCS STK Net GstarCAD.dll'
or one of its dependencies. The system cannot find the file specified.
File name: 'file:///C:\KetcauSoft\KCS_STK\KCS STK Net GstarCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/PT Section/PT Section Net
'file:///C:\KetcauSoft\PT Section\PT Section Net GstarCAD.dll' or one of its
File name: 'file:///C:\KetcauSoft\PT Section\PT Section Net GstarCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS IFDe/KCS IFDe GstarCAD.dll Cannot
load assembly. Error details: System.IO.FileNotFoundException: Could not load
file or assembly 'file:///C:\KetcauSoft\KCS IFDe\KCS IFDe GstarCAD.dll' or one
File name: 'file:///C:\KetcauSoft\KCS IFDe\KCS IFDe GstarCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/PFDe/Pile Foundation Detailing
ZWCAD.dll Cannot load assembly. Error details: System.BadImageFormatException:
Could not load file or assembly 'file:///C:\KetcauSoft\PFDe\Pile Foundation
Detailing ZWCAD.dll' or one of its dependencies. This assembly is built by a
runtime newer than the currently loaded runtime and cannot be loaded.
File name: 'file:///C:\KetcauSoft\PFDe\Pile Foundation Detailing ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/RCB/RCB Net ZWCAD.dll Cannot load
assembly. Error details: System.BadImageFormatException: Could not load file or
assembly 'file:///C:\KetcauSoft\RCB\RCB Net ZWCAD.dll' or one of its
dependencies. This assembly is built by a runtime newer than the currently
File name: 'file:///C:\KetcauSoft\RCB\RCB Net ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/RCS/Reinforced Concrete Slab
Could not load file or assembly 'file:///C:\KetcauSoft\RCS\Reinforced Concrete
Slab ZWCAD.dll' or one of its dependencies. This assembly is built by a runtime
File name: 'file:///C:\KetcauSoft\RCS\Reinforced Concrete Slab ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/RCCd/RCCd Net ZWCAD.dll Cannot load
assembly 'file:///C:\KetcauSoft\RCCd\RCCd Net ZWCAD.dll' or one of its
File name: 'file:///C:\KetcauSoft\RCCd\RCCd Net ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/CTK/CTK_NET_ZWCAD.dll Cannot load
assembly 'file:///C:\KetcauSoft\CTK\CTK_NET_ZWCAD.dll' or one of its
File name: 'file:///C:\KetcauSoft\CTK\CTK_NET_ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/QuickDraw/Quick Draw ZWCAD.dll Cannot
load assembly. Error details: System.BadImageFormatException: Could not load
file or assembly 'file:///C:\KetcauSoft\QuickDraw\Quick Draw ZWCAD.dll' or one
of its dependencies. This assembly is built by a runtime newer than the
File name: 'file:///C:\KetcauSoft\QuickDraw\Quick Draw ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS_LAT/KCS LAT ZWCAD.dll Cannot load
assembly 'file:///C:\KetcauSoft\KCS_LAT\KCS LAT ZWCAD.dll' or one of its
File name: 'file:///C:\KetcauSoft\KCS_LAT\KCS LAT ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS_Plotter/KCS_Plotter_ZWCAD.dll
Cannot load assembly. Error details: System.BadImageFormatException: Could not
load file or assembly 'file:///C:\KetcauSoft\KCS_Plotter\KCS_Plotter_ZWCAD.dll'
or one of its dependencies. This assembly is built by a runtime newer than the
File name: 'file:///C:\KetcauSoft\KCS_Plotter\KCS_Plotter_ZWCAD.dll'
at loadmgd()
logging.
Detailing ZWCAD.dll Cannot load assembly. Error details:
System.BadImageFormatException: Could not load file or assembly
'file:///C:\KetcauSoft\KCS_SFD\KCS Spread Foundation Detailing ZWCAD.dll' or
ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS_STK/KCS STK Net ZWCAD.dll Cannot
file or assembly 'file:///C:\KetcauSoft\KCS_STK\KCS STK Net ZWCAD.dll' or one
File name: 'file:///C:\KetcauSoft\KCS_STK\KCS STK Net ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/PT Section/PT Section Net ZWCAD.dll
load file or assembly 'file:///C:\KetcauSoft\PT Section\PT Section Net
File name: 'file:///C:\KetcauSoft\PT Section\PT Section Net ZWCAD.dll'
at loadmgd()
logging.
netload Assembly file name: C:/KetcauSoft/KCS IFDe/KCS IFDe ZWCAD.dll Cannot
file or assembly 'file:///C:\KetcauSoft\KCS IFDe\KCS IFDe ZWCAD.dll' or one of
its dependencies. This assembly is built by a runtime newer than the currently
File name: 'file:///C:\KetcauSoft\KCS IFDe\KCS IFDe ZWCAD.dll'
at loadmgd()
logging.
Loaded... Start command with [CBig GrinM].
Sap xep dim, SD - free lisp from http://www.cadviet.comType "DG" to startApplication
ERROR: Invalid type sent as command input
Command: (command "rccdraw") rccdraw Unknown command "RCCDRAW". Press F1 for
help.
Command: nil
 Thanks given by: DarylUrips , RazorDK , MichaelHyday , JustinMem , Thomaspheld , prooknann , SHALOMAdup , Aabertdasty , MiguelRof , CARAdup , DennisDus , REMONTAdup , NegsonFix , BillieEmome
04-07-2019, 01:38 PM (Bài viết đã được chỉnh sửa: 05-07-2019 07:42 AM bởi Ho Viet Hung.)
RE: LỖI KHÔNG SỬ DỤNG ĐƯỢC LỆNH KCS
(04-07-2019 11:28 AM)ducmanh169 Đã viết:  LỖI KHÔNG SỬ DỤNG ĐƯỢC LỆNH NÀO CỦA PHẦN MỀM KETCAUSOFT
anh cài đặt lại thử phần mền ketcausoft lại xem được không anh.
 Thanks given by: Louishix , TommyX , MilesRit , Georgeycf , dapyroyalay , annabellehb2 , ChrisBipsy , JasonEther , Rafaelfaw , Charlesvine , Amchiealem , Kesnethpt , Aabertdasty , franEa , Dominicmn , DarylUrips , Arthuret , HoraceRold , freidaef2 , thomasdg16 , alexanderin11
04-07-2019, 05:02 PM (Bài viết đã được chỉnh sửa: 05-07-2019 07:42 AM bởi Ho Viet Hung.)
CẢM ƠN ĐỘI NGŨ KETCAUSOFT NHÉ!
MÌNH CÀI LẠI BỘ PHẦN MỀM LÀ ĐƯỢC RỒI
 Thanks given by: DarylUrips , Thomaspheld , Neeraviefs , Cecilsuest , Artvertoffins , dapyroyalay , JoshuaKib , JustinMem , Aabertdasty , MaxenceU , Lonnieei , HowardNus , PatrickPit , dellafw3 , janisvr3 , alicebi11 , lorenaxt4
